1 - 20 of 22 Posts
If it annoys you that the side mirrors continue to drip and streak after you dry your SSR, try this:
Wash normally and dry the mirrors first. Then push them forward while you dry the rest of the car. This puts the mirrors at an odd angle and the water drains out quickly instead of dripping for an hour. By the time you finish drying the rest of the car, the mirrors have leaked about all they are going to. It's not perfect, but it works better than doing nothing.
Texster68
it's 5 o'clock somewhere!
that's right
texster68 - I never would have thought of putting that tip out there, but you are right on the money. Been doing that since I got it and it works great.
Sandy
Great tip!
Thanks for the great tip on the mirrors.
What do you all use on the chrome wheels?
SSRBH
Just a caution regarding moving the mirrors around. Be very careful! I drove C5 corvettes for 7 years and one of the 'vette mechanics cautioned me about playing with the mirrors too much. Apparently the spring mechanism inside the mirror is made of die-cast metal (read "pot metal") and doesn't tolerate any rough handling.
Apparently if the mechanism breaks it's a real bi*** to repair.
Banned
I drilled (a C5 Corvette Trick) a small hole into the bottom of each mirror housing and now its a non issue! :)
2005 SSR LOW MILES
Washing Ssr
TEXSTER68 THANK YOU FOR YOUR TIP ON HOW TO WASH MY SSR....I WANT TO THANK YOU AGAIN FOR THE FRONT AND REAR StabiliSSR.AWESOME PRODUCT THANK YOU:cool
Put cheapy shower caps(like the freebees in hotels) over the mirrors, after you wash and rinse the SSR take off the shower caps and just clean the mirrors with a damp cloth after. Stops the flood coming out of the mirrors as you pull away with you freshly washed SSR.
Could you give me an idea exactly where you placed that hole so I won't put it in a location that will drain it properly? A photo would be great.
revet....put down the drill and step away from the SSR ... if you do a search you can nice plastic covers made for I believe it was a C5 vette mirrors that work on the SSR. I have them, use them and they work awesome. Slip them on before you wet down the car and after your finished pop them off. No fuss no muss NO DRILLING!!!!
Coz.
if you do a search I know I posted the links a long time ago like back in October.
SSR Washing Tip
I use on my Vette all the time. Get a package of Scott Shop Towels on a roll. They are blue in color. After you wash the SSR stuff a towel in the corner of the mirror. By the time your done detailing simply throw the towel away. They absorb water like crazy. :cool
Tu-Tone club member
I use forced air to blow the water out....same as the wheel lug nuts.
P/P
Peace:flag
an old motorcycle washing trick works on the wheels - take your leaf blower and blow the majority of the water off. Then you can towel dry what's let - The air really works on all of the little nooks and krannies
1 - 20 of 22 Posts
