  •  2022 Ride of the Year
START HESITATION!
308 Views 10 Replies 6 Participants Last post by  Dicktator
Hello All! My R Has developed a hesitation during starting this spring, New Gel Battery last year, New ground cable from Simple Engineering! Every time I try to start get the hesitation then cranks good, but the clock and the Radio resets! Any Ideas?
  • Wow
Reactions: 1
1 - 11 of 11 Posts
Sounds like a ground problem. The starter pulls all of the available power but with out a proper ground you lose connection and that is why the clock and radio lose power. Go back and check and clean the frame where the ground cable attaches, also the bolt an lubricate. Check the connection at the ground to the body also. Pull both positive and ground connections at the battery.
Jack
  • Helpful
Reactions: 4
Jack
I will try In the morning, thanks
Both versions of the SSR, '03/04 and '05/06, have numerous body grounds. Look in Dicktators repair manual online and I believe he maps out the various grounds. I know I have seen them detailed somewhere, but with the starter hesitating it is probably a main cable problem. Also check both wires at the starter solenoid and both connections at the battery to make sure that they are clean and tight. With a new ground cable, it should be OK, but it never hurts to be sure. A couple of issues with year old batteries have been detailed in the last couple of weeks in different threads. Good luck.
Reactions: 1
The clock reset indicates that the main power is being interrupted momentarily. Could be the positive or negative cable.... I would put a meter on the positive terminal of the fuse box and monitor the bus voltage when trying to crank it. If that shows a big voltage dip, put the meter on the battery terminals and do it again. If it dips there, yank the battery out and have it tested for cold cranking amps. Could very well be that battery.......
Reactions: 1
Cleaned and lubed all grounds,Removed both cables from battery! no luck Going to remove battery and have it tested at the Store
Reactions: 2
keep us posted on this thread---
Steve
Steve
Sure will! Thanks for all the input!:cool:
Went to Advanced Auto this Morning They could not test my battery so they just gave me a new one! Every thing works, clock and radio remain set and no hesitation during start! 9 month old Optima red top Bad!!!!
Thanks everyone for your input!
Forever Grateful
Lou Laskay(y)(y)(y)(y)
Reactions: 5
Thanks for the update---Optima makes a great battery--but you never know---
Steve
BOY! I'll be glad when we go to "ALL ELECTRIC" vehicles, only need two "D" battery to "jump" start your R.
New Battery in Florida last 6 months to 4 years, depending on how HOT it gets.
1 - 11 of 11 Posts
