I'm planning on installing a DAB+ receiver (european digital radio) along with a iSimple connect ISGM655 in my SSR.
Ideally the receiver would only be powered when the stock radio is on.
Is there a wire on the car radio harness that I can splice to control a Relay to switch power to the receiver?
(or when the iSimple is operating as the receiver will use it's aux input)
I wil tap into the sigarette lighter or one of the power outlets for power, but those are powered all the time.
Additionally, is there a wire I can splice from to control a relay to change one of the power outlets to only be powered when the key in in acc or run position?
Or even beter with the battery rundown protection timer of 10 minutes after the key is turned to off position
(actually I dind't check yet if the timer actually works for the lamps, but I'm pretty sure the timer doesn't apply to the power outlets as the manual states)
