No to both questions. All changes where made aft of the CAT flange and sensor bung. Also no check lights or any other problems with drivability other than some passenger discomfort above 4,000 RPM with the top down or window open. You get some attention when idling around the local parking lots when in the FUN mode also.
It would seem to me that if you ran the dump pipe around the muffler and reconnected it, much of the noise would run out the back to one or both of the existing tail pipes. That might help your hearing loss ! Your opinion, please!
Routing the bypass around the stock muffler then tieing into one of the rear outlets would be an easy thing to do, it would be a lot quieter due to the length of the pipe and exit out the rear. If it didn't make enough noise that way or sounded funny for some reason you could always just make the sidepipe like mine and reroute it without too much additional effort.
I replaced the muffler with a Magnaflow that is quite a bit shorter, so now in normal mode it sounds a bit louder and just right for all driving. I do not use the Fun mode (open exhaust on the side) for any extended period and not very often, so hearing loss is really not an issue for me. My plans are to eliminate the rear tips, fill in the cutout area of the rear facia and put turndowns on the twin rear pipes so all that will be exposed will be the side pipe. Just my opinion but I personally like the looks of a side pipe better with this body style than the rear exhaust.
Pushrods....In doing this you could go with the MPD rockers and cutout the area of the rocker so the side pipes are embedded for that clean smooth look. The main problem with side pipes is the exhaust buildup on the outside. The "FUN" mode usage wouldn't create this kind of situation.
While we are on the subject of Nitrous, I had my 05 on the Dyno yesterday at Dennis Reinhart's shop. Had to shut it down early as I am not quite ready to do the tuning, but suffice to say it broke 500hp at the wheels. Only mods are a NOS kit and a K&N.
Dennis fitted my 4:56 gears as well. On the long drive home, I could only wonder why Chevy didn't build them this way in the first place. In a word, fantastic. The car actually responds to the throttle in top gear on the highway now, and first gear fels like, well, first gear, rather than second. Have to believe this will be a big help at the track.
Just want to say Dennis is the best. He and his team really care about their customers, tough to find nowadays!
Do you really think that you need the 4.56 gears with the Nitrous? I was thinking the taller ratio would actually help keep the tire connected when the HP kicks in...
Just trying to figure out which option is first -- both seem to be around the $750 range. :banghead
The all round driveability improvement from adding 4:56 gears is pretty dramatic. I get to enjoy this every time I am out in the truck. I probably won't be back at the track for a few weeks, so I have no data yet, but that long first gear used to cause a significant bog. I have to believe that will be significantly improved.
In the end, if I now have traction problems at the track, I will be adding stickier tires!
Nitrous cannot be activated at low rpm, because it will bend conencting rods and / or break pistons if applied at low rpm!
Our SSRs are HEAVY, so they really need more power at launch.
Therefore, with nitrous, the stiff gearing IS an important advantage.
Now with a supercharger, you get a lot more power right at low rpm. There, the gearing question is more importamt to at least consider (I DO want my 4.56 gearing with the supercharger! )
At the moment, the windows and the roof do not rise and fall.
There is no signal to turn on the air conditioning compressor.
The RDM module was purchased used by one of the previous owners. From the information I have, windows and roofs never worked.
When reading errors, there are three not...
Just before I put the R away for it's long winter nap the speedo quit working. After some investigation on the forum it looks like I will be replacing the step motors in the spring. Where is the best place to purchase them? Saw a kit on e-bay the included soldering iron and solder sucker. I...
I live in eugene oregon. Anyone know someone that works on SSR's. Just had my heater go out after it had been ticking for about a month. Thanks from Skubadoo.
