1 - 3 of 3 Posts
@Dictator, I looked at my water pump and it is showing signs of leaking. On the thread that you had about replacing it you said you had to replace the thermostat housing. Was that just for the brand you bought or do all of them have to be changed. Thanks, Robert
I was told that the OEM will not transfer to aftermarket water pump, so we bought one along with water pump. Cheap enough that I didn't check at the time.
You can try buying water pump from Dealer and transfer housing, then you will know.
I do know that the aftermarket pump and aftermarket thermostat housing do fit!.
1 - 3 of 3 Posts
