I have seen other threads on the front and flex. While going through my front end installing new bushing and ball joints I came across some things that made me scratch my head. Most cars using struts have the struts tied into the upper unibody frame rail and inner structure. They then go down to the spindle and mount to the spindle. Most set ups that I am familiar with don't even use an upper control arm they use the lower and the top of the strut all tied together as a triangulated suspension.
Ours uses both an upper and lower control arm with the spindle connecting the two. The strut connects to the lower control arm with a yoke that ties into the lower control arm through a rubber bushing in the control arm. The strut comes down and then attaches to the yoke. The yoke takes the line from straight downward to off set it to the front side of the A arm. The Strut mounts to this yoke with a collar and pinch bolt. The top of the strut mounts with a bushing plate with 2 studs that mount it to the frame. This is another thing not like most other strut applications. Most either have a plate with either 3 or 4 mounting bolts with slots for adjusting the top of the strut.
So my first question is could this yoke, off set lower mount and rubber bushing mounted stud for the lower mount be causing some flex in the front end? Next on a lot of cars the upper mounts or strut towers, if they have flex issues they will add either a cross brace across from one side to the other or if it is going to see a lot of abuse they will use a K type brace tying the strut towers into the firewall also. Now the upper strut mounts on our trucks are so low that to make a brace it would have to come up and over the engine and it would be so big that it would probably have too much flex to it to do any good.
Now the next thing that got me to wondering is the way our body is on the SSR. Most full frame vehicles have the cab and bolt on fenders with a front core support mounted on rubber bushings. This set up has no flex from the front end to the cab. Ours has welded upper inner frames and across the front at the core support area all welded to the cab structure. We also have the entire body and bed all as one unit. Could this big of a body structure be causing the flex to carry into the cab and felt in the steering wheel more? I know there were some old Ford pick ups that the cab and bed as one unit but back then people weren't using their trucks like we do.
Ok what do some of you guys who have worked on these over the years think?
