I just put a set of wheels on my SSR today, the guy put 44lb of
air in each.
It seems to ride a little "sharp" on bad roads.
What pressure do some of you run in the stock 19 an 20 inch tires?
Thanks Eddie
air in each.
Thanks Eddie
Eddie,
I always follow the manufacturers recommended tire pressure listed on the drivers door.
The door says 30 PSI. So, I put it at 31 or 32, just because tires tend to lose a little air if you only check them once a month like I do.
I'm with them that puts in the amount indicated on the door sticker.
I have 20kmi on my tires and the wear is dead even across the entire width.
I recently had my tires rebalanced, the chap checked them and put in 40lbs. I noticed the additional ride harshness within the first 1/2 block.
