Front and back not the same size. Cannot rotate.For my daily drivers, next time I purchase tires.
I will be looking for some that I can dismount and rotate.
I want more Bang for my Buckeroos 💵
FYI
If the tires are non - directional tires then they can be dismounted and rotated from driver side to passenger side.Front and back not the same size. Cannot rotate.
There might be a problem with terminology. The term dismount refers to the process of taking the tire off the wheel. It is not used to describe the process of taking tire and wheel assembly off of the car.If the tires are non - directional tires then they can be dismounted and rotated from driver side to passenger side.
I meant dismount the tires off the wheels because, some will still have uneven tire wear on the inside of their tires even after a wheel alignment. This way we hopefully get a few more miles on our investments.There might be a problem with terminology. The term dismount refers to the process of taking the tire off the wheel. It is not used to describe the process of taking tire and wheel assembly off of the car.
You would need to dismount if tires (or wheels) were directional. Asymmetrical tires can be moved side to side without being dismounted.
So probably just say "rotate tires side to side"
And from my time at a tire store that was into radials, I have always read & been told never to change the direction of rotation of a radial tire once driven on, thus front to rear rather than the old X-rotation scheme for bias-ply tires. Has that warning been changed with the construction process of modern radial tires. Same rule for serpentine belts.There might be a problem with terminology. The term dismount refers to the process of taking the tire off the wheel. It is not used to describe the process of taking tire and wheel assembly off of the car.
My Michelins are not directional so according to the owner of our tire jobber they can go side to side, or if same size front to back. I am not an expert, but I have been doing it on my other vehicles including 4wd, awd and front wheel drive. But, I get the alignment check every 20K and rotate at 5K.And from my time at a tire store that was into radials, I have always read & been told never to change the direction of rotation of a radial tire once driven on, thus front to rear rather than the old X-rotation scheme for bias-ply tires. Has that warning been changed with the construction process of modern radial tires. Same rule for serpentine belts.
If you want to talk about tire wear I only got 4000 miles on my 2017 Z06 with no burn outs $$*$AD. That is me on the R. Except I use my 10 year old RSA's on my worst rims in the winter. Very limited miles there.
We have put on 5K to 6K every summer except for Covid year. Even the Michelin SS's have not worn down and probably won't before they age out.
