While at Sears today, I found an inexpensive lighting solution for the cab / bed in the automotive department. It's called a "Flexible 12 volt PORTA-LIGHT" made by Schumacher for $5. It plugs into the receptacles and has a 6" flexible neck; kind of like a desk lamp, with an on off switch, and it's Bright! It's also flat black so it blends with the interior perfectly. Should be able to leave it always plugged in, and bend it under the dash out of the way until needed. Got two, for back and front. Richard
