1 - 8 of 8 Posts
Just got a 2006 SSR and can not find how to get the light attached to the cover to work at night
Any clues ,
thanks
Gigi
@gigissr, Welcome from Forney Texas. Consider clicking on the Colored Letter/Picture, top far right corner, go down to "Account Settings", click, and fill in your information. Especially your LOCATION and the year of your SSR, like the rest of us. Then go the the left side and click on "Signature". Also put the year of your SSR in your "Signature", and anything else you want to show in your posts, and we can help you better if you have a problem. When you finish click the "SAVE" box.
Nick & Kathy
Spirited driver!
Any clues ,
thanks
Gigi
As you will see in Dicktator's instructions, you should swap out the bulb with a LED and the fuse with a 1 or 2 amp fuse. Yours may just have the fuse out. Do the LED & fuse swap to avoid a bed fire.
Discussion Starter #6
Thanks All you SSR Fanatics
Will check all your suggestions
Can any one tell me if there is a SWF chapter around Fort Myers
Thanks Again
Gigi
Thanks Again
Gigi
Gigi, see post #3 above--
1 - 8 of 8 Posts
