1 - 20 of 88 Posts
top does nothing (it does now) Thanks to everyone
ok, have been doing some reading, read that ac has to be off to put top down. This is what I tried. Truck running, depress brake, roll windows down. depress button on console. get message on dash to put top down manually.
it's 5 o'clock somewhere!
AC does not have to be off to put the top down. That's a fact.
I always have the truck running to put the top up or down. That's just a good idea because of the power it takes to do it.
You don't have to have the windows down before you push the top (up or down) button. They will go down by themselves when you hit the button. Rear truck bed cover must be closed.
Yes, at a stop, foot on the brake and then push the button. When the top starts to move you can take your foot off the brake and roll along very slowly.
Not sure why your top isn't cooperating.
Your "on it like Bluebonnet" turnheadz ... I've never heard anything about the AC having to be on. I always put mine in Park, Foot on Brake, Push Button. RESULT: Windows go Down, "Flaps" Raise Up, Top Unlatches and Top Goes Down. Flaps Go Down and off we GO !!! tennesseedoggie :ssr
I have the impression that the top is up and locked. If that is true, we can do a little troubleshooting, try this.......
Begin with the engine off and windows up.
Turn the ignition to the “run” position without starting.
Depress brake and depress “top down” button.
Do the windows go down all the way?
Can you hear any running sound from the hydraulic pump motor?
What is your error message?
Next steps depend on your answers.......
Discussion Starter · #5 ·
tried pushing the button to lower the top again today, now it says bed cover ajar, I'm at a loss. but I will win the battle of the top.
Discussion Starter · #7 ·
ok, pulled both silver relays out, that were in the fuse box behind the pass. seat. gonna leave them out for half an hour.
Discussion Starter · #8 · (Edited)
did not help, but got different message, manually open tonneau cover. ok talked to a local guy who has a SSR, he said a low battery may be causing my problems, What do ya'll think. Just bought It have no idea how old battery is.
Discussion Starter · #10 ·
tried it with it running, but did notice my trunk light is not working.
Seems like the wiring in the connector for the light also has something to do with sensing the Bed cover being closed!? You may be on to something. Someone else may chime in.
Discussion Starter · #12 ·
well at a loss, about the top problem, But tomorrow is another day.
Discussion Starter · #14 · (Edited)
fuse 27 under the hood says W/S washer, pulled fuse 27 under hood and pull #40 fuse behind the pass. seat.
My cargo lid light just has the wiring cord hanging down from it. It is not at all connected to the power source to operate..............meantime, my top goes up/down without any problems.:wink2:
Discussion Starter · #16 ·
how long do I need to leave fuse # 27 out? under hood. says W/S washer.
Discussion Starter · #17 ·
put fuses back in, getting message: manually open tonneau cover.
Discussion Starter · #19 ·
pushing the top up button, I still get open tonneau cover manually. do not hear pump running, windows never move, they are all the way up.
Daily Driver
I wonder if it's an early build '04 with the funky hinges on the tonneau cover?
Sounds like your best bet is to pull the cables to unlatch the tonneau cover and lift it manually.
1 - 20 of 88 Posts
