I have had a roof problem for a long while now, I have to manually lift up roof lid and then I can drop the top with top switch. goes down and closes fine and the 2dings. then when putting top up top lid opens and top comes up and locks but the top lid just moans . I shut off engine and gently push it down. no 2 dings and dash shows top not locked. Something I can fix myself???????? any info appreciated.
BLU SSR
What year is your SSR? 03's and some early 04's I believe had some problems with the hinge design which did not allow the lid to lift up slightly before it rotated, if yours fits this category, check for some wear spots in the paint indicating interference. Also are you located close to Chicago - I don't find a Griffin on my Atlas.
2004/ Griffin In. last exit I 64 before crossing the Wabash River entering IL. if so can I replace hinge and are they available?
Do you get any type of error message on driver information center when trying to lower top?
See the power point on the one drive regarding top failures.
Also see this thread
So the lid cover does not open when retracting roof, does open when you command a roof close, but after the roof is up the lid cover fails to close?
If it were a hydraulic pump or cylinder issue I would think it would fail both up and down when commanded to open whether top was up or down. I am thinking a sensor issue but as Autoprof mentioned, need Driver Information Center Code to help.
Dicktator and others have some good info in the Library, WOW_FCTR had a nice description of roof operation, here is a small snippet that might assist you as well. ...........
"The sequence for opening the top is as follows when holding the retractable roof switch to the OPEN request position:
1. Driver and passenger windows index down
2. Tonneau latch extending to unlatch
3. Tonneau latch extended, opened
4. Tonneau panel extending upward, opening
5. Tonneau panel extended upward
6. Front tonneau extending
7. Front tonneau extended
8. Header latch unlatching
9. Top panel dowel pins activate that top panel is not over center and unlatched
10. Top panel retracting, to open position
11. Top panel retracted to open position
12. Tonneau panel retracting downward, closing
13. Tonneau panel closed
14. Tonneau latch, retracted
15. Audible chime 2 times indicated cycle completed
The sequence for closing the top is as follows when holding the top retractable roof switch to the CLOSE request position:
6. Top panel extending to close position
7. Top panel dowel pins enter receiver indicating top reached header
8. Header latch latching
9. Top panel dowel pins activate that top panel is over center, latched
10. Front tonneau retracting
11. Front tonneau retracted
16. Driver and passenger window close
Hydraulic Control
The roof door module (RDM) will control the hydraulic system to move the folding top by controlling the on/off state and direction of the hydraulic pump motor, and the open/close state of each valve.
The pump motor will be continuously monitoring the temperature sensor thermistor for a pump motor temperature being out of range. If the RDM detects a temperature between the pump motor pre-alarm and pump motor alarm, the current open/close operation shall complete, but no new top operation will be allowed until the pump motor cools below the pump motor pre-alarm. If the temperature reaches the pump motor alarm value, all top operation will cease. There is a low temperature value that will also cease all operation when the temperature is below this value.
Anytime the folding top control switch is released or the top becomes inoperative when it is not fully closed or open, pressure must be maintained in the system to avoid drifting and damage of components. After 4 minutes, hydraulic pressure should be released by cycling the valves on and off, allowing the top to gradually settle to a resting position.
Driver Notification
Listed below are under certain conditions the driver shall be alerted with a message sent via class 2 serial data to the driver information center (DIC).
• ROOF CYCLE TIMEOUT -- Displays when the folding top switch is active and the RDM has detected a fault that could potentially bind the system possibly causing mechanical damage. Roof operation ceases when this message appears.
• PUT VEHICLE IN PARK -- Displays when cargo cover is released as vehicle is out of park.
• STOP VEHICLE -- Displays when cargo cover is released as vehicle is moving.
• ROOF AJAR -- Displayed when cargo cover is released and roof system is not fully opened or closed.
• CARGO COVER AJAR -- Displays when folding top switch is active and the cargo cover is open or ajar.
• PRESS BRAKE -- Displays when folding top switch is active while vehicle is stopped and the brake is not pressed.
• REDUCE SPEED -- Displays when folding top switch is active while vehicle is above a maximum speed.
• UNKNOWN ROOF POSITION -- Displays when folding top control switch is active as either the folding top panel, stowage compartment lid panel or stowage compartment lid extension panel exceed the parameters of there set positions.
• HDR LATCH SWITCH FAULT -- Displays when folding top control switch is active and a fault is present with either the latched or unlatched limit switch.
• ROOF HALL SWITCH FAULT -- Displays when folding top control switch is active and a fault is present with either the top panel extended or retracted hall effect switch.
• TONN HALL SWITCH FAULT -- Displays when folding top control switch is active and a fault is present with the stowage compartment lid panel extended hall effect switch.
• TLAT HALL SWITCH FAULT -- Displays when folding top switch is active and a fault is present with the stowage compartment lid panel latched, left or right, hall effect switch.
• TONN LATD SWITCH FAULT -- Displays when folding top switch is active and a fault is present with either the left or right, stowage compartment lid panel latched switch.
• FLIP HALL SWITCH FAULT -- Displays when folding top switch is active and a fault is present with either the stowage compartment lid extension panel retracted or extended hall effect switch.
Switches
The folding top system monitors inputs from hall effect switches to determine the position of various components and to control the folding top system sequence. A hall effect switch that is attached to a hydraulic cylinder will become active, 1.5-3.5 volts output to RDM, as a cylinder reaches it's fully extended or retracted position based on the location of the hall effect switch.
The stowage compartment lid extension panel hall effect switches become active as the stowage compartment lid extension panel cycle approaches the extended or retracted positions. The hall effect switches are active as they sense the magnetic field as the cylinder approaches each end of it's travel, causing the switch to become active, 1.5-3.5 volts.
The header has a folding top outer latch actuator with two limit switches that monitor the header latch position, and a dowel pin limit switch to monitor the roof panel at the header. As the folding top panel is closing up to the header, the dowel pin, as it first enters the pin guide receiver, signals the RDM that the top is at the header and aligned. The RDM will control the folding top outer latch actuator to latch, pulling the top panel closer into the header. The dowel pin will enter further into the pin guide receiver, again signaling that the top is now over center and latched. The folding top outer latch striker position switch will also signal an input to the RDM confirming that the top is latched and to stop the control outputs to the folding top outer latch actuator. "
? Add your location on Fanatic PINMAP and locate others
Custom Billet Accessories - Shift adapter, letters, satin/polished, etc
