Last Wed. I pulled off the freeway and stopped to put the top up. (The crosswinds were killing me.) Back up to speed and there was a new noise, wind from the right side. I ran that window up and down, still noisy.
At home, I got out to look around and there was a noticable gap between the window back side and the C pillar weather strip. (or is it a B pillar on a truck). I cycled the top and windows again, and did the manual down/up trick for the rt window.
The gap closed up about 1/2 way. Some of the wind noise went away.
Tonight: Using a steel rule, I measured the various gaps and joint alignments. By my analysis the lower half of the top is shifted back 3-4mm on the right side. Like maybe, the top's hinge on that side is mispositioned.
Whoever put all this together cheated a number of places to try and minimize the gap at the back of the window. Not much, a little stretch here, a little there "The weather seals will cover it." For example, the rt. window is farther back in the door than the left. Not much, not really noticable, until you go looking for it.
I truly hope it's just a case of a bunch of minor misalignments stemming from a first error, and isn't misadjusted to conceil something darker.
