1 - 15 of 15 Posts
I have been looking a two touch-up paint companies Dr. Color Chip and Langka. I used Langka about 4 years ago and was pleased. I don't know if anyone has other companies they have used and had good luck with. Thoughts?
I use nothing but DR Color Chip. Works perfect on the Yellow. I have tried others and they always leave a big blob. With DR you dab it on, let it dry a few seconds and rub it off with this special solution they provide. You keep doing that until the chip is filled but there is no paint outside the chip area and it is very flat and level. Polish it and within a couple hours you can't even remember where it was. I have had some deep chips up front and on the mirrors and can't even find them now. Like I said I only know how it works on Yellow. Might be different on the other colors. I am sold on it.
Click here:
Great review Auggie! I'll have to keep that in mind and see how it matches Pac Blue. With it being metallic might be more difficult to match... Only one way to find out. Not doing it anytime soon though...
Looked at Amazon at 3 pages of colors and got this response
"We cannot find any "doctor colorchip" for your 2006 Chevrolet SSR.
Try checking your spelling, using more general terms, or:
Clear vehicle filter ❯ "
They go by your paint numbers not name.
Aqua Blur......................26U...........................WA-214M
Smokin Asphalt..............41U...........................WA-8555
Ricochet Silver...............67U............................WA-994L
Redline Red....................70U............................WA-9075
Slingshot Yellow.............79U............................WA-423G
Pacific Blue....................90U...........................WA-885K
Ultra Violet....................21U...........................WA-245E
I order from them direct.
SSR Believer
I’ll add my vote for Dr. ColorChip. (y)
I‘ve used all sorts of touch up paint over the decades, some terrible, some pretty good.
The Paint in the kit from Dr. ColorChip matched our Aqua Blur perfectly. Following the directions resulted in almost imperceivable repairs of some quite noticeable scratches and dinged paint on the front end. It’s not a quick process. It takes time and patience. A few required more than two or three applications to fill them in to meet the original paint level. Well worth it though.
I was a pretty big skeptic, especially based on the price, but it was recommended by other Fanatics at the time. I was really amazed at the results.
After a complete clay bar, paint cut and polish detail, the repairs are still intact.
EDIT: Dr. ColorChip is offering a 15% discount as of this post date. Enter the code WINTER at checkout.
I use Dr Color Chip on my black SSR as well as our previous yellow SSR and the match is perfect. Also used on my Camaro and very pleased. Ordered direct should have coupon code for free freight. Well worth the price.
This is terrific! I have been looking for a paint chip application that works and does not leave that
dreaded blob that always looks as though you just tried to cover a paint chip - one question I could not find the answer for, perhaps one of
you can provide the answer - I did not see any mention of clear coat finish, guess it is not necessary with this product? Just wax over the
chip once it has had the opportunity to cure?
SSR Believer
You'd have to watch the videos or read the materials, but IIRC somewhere along the line they address clear coat in the paint and/or sealer description. Something to the effect that there's no need for another layer if you follow the directions to bring the repair area to the same level as the existing paint.
As @PokerGuy said, just a good coat of wax will take care of it. That's what I did and it's honestly hard to find any of the repairs on our R unless you really know where to look and even then sometimes I'm not sure.
One helpful tool is a very bright light to both find imperfections and to review your repair. Scratches (unless they're to bare metal) are visible because they refract light differently than the surrounding surface. As your repairs even out the surface they disappear. I bought this NEBO 400 Lumen LED light a while back and it works perfectly for finding imperfections (also great for under the hood work, etc.)
Best of luck and let us know how it goes!
Click here:
Which kit did you buy?
Discussion Starter #12
Thanks to all. Great discussion. I am going to go with Dr. ColorChip.
With regards to Langka they do make a good product and their Blob Eliminator works .
I just got the smaller kit to start out with. It had everything you need. I went small because I thought it might not work as good as they said but I was really surprised. You don't use much so the small kit worked fine. Over the winter I cleaned my SSR good first and then started in one place and did a little everyday until I went around the entire vehicle. I have a lighted and heated garage so just did a little each day until done. Since then I touch up any new nicks but they are few. I have installed 4 rubber mud flaps and have full running boards and stay off gravel roads.
I think this is the kit I got. It has been over a year ago but I think it was about this price and had all the things mentioned in a small box. Good luck.
Click here:
Discussion Starter #14
Click here:
Thanks. I ordered the Dr ColorChip Squirt and Squeegee kit, Used the "WINTER" code and got the discount, Thanks all.
Skip
Discussion Starter #15
I started some of the scratch and chip repair yesterday. Two thumbs up for Dr ColorChip.
My "R" is Ultra-Violet (Paint Code 21, WA245E). For those who have UV's the paint is also called Radar Blue and was used on 1998 Corvettes. It matches perfect. Dr ColorChip supplies it as Radar Blue.
Extremely pleased with the Dr TouchColor touch-up paint kit.
As I stated earlier that I have used the Langka touch up paint system as well and it works fine.
I observed that the Dr ColorChip paint has a very quick dry reducer and sets up fast and the only paint you can used with the Dr ColorChip kit.
Whereas the Langka supplied Blob Remover can be used with any touch up paint.
Skip
1 - 15 of 15 Posts
