Does anyone know if you can tow these four down? I may trade off my Dually and 5th wheel for a motor home.TIA,Dave
If a vehicle is not towable 4 wheels down from the manufacturer they will tell you in the manual it's not towable. They are protecting themselves. There are aftermarket products that can make the towable. Years ago I had an 03 Escalade. It was AWD , not 4 wheel drive with a transfer case . The truck was not towable 4 wheels down but I installed a lube pump and then you could tow it. Someone mentioned FuryKay flat towing SSR's. I used to see him many years ago at motorhome rallies and I would bet he flat towed them with a driveline disconnect and the truck would have been a stick.The owner's manual states that the SSR is not desiged to be towed with any of its wheels on the ground, and "Do not tow your vehicle with all four wheels on the ground."
If the driveshaft is disconnected why would it have to be a stick?I used to see him many years ago at motorhome rallies and I would bet he flat towed them with a driveline disconnect and the truck would have been a stick.
John F.
Yes but pulling it behind a 42' 5th wheel wouldn't look bad either.Just be really long.:surprise:Awww, it sure would look good on an Aluminum car hauler behind the Dually!!
