Guest
·I've been looking for a reason that GM limits the towing load to 2500lbs on the SSR, question is WHY?.... I've heard it said that the SSR will not handle the extra temperature load put on the engine, Also that the frame will not hold up to a heavy tow, can anyone answer the question?
The SSR IS a truck, and it weighs somewhat about the same as my 04 Silverado LS ext cab, so weight of the towing vehicle can't be the reason, If it is a heat up problem then a larger more efficient radiator and trans cooler should do the trick.
It CAN'T be lack of power.
I have a radical custom 49 chevy chop top coupe that I would love to take to shows on a trailer ..Behind an SSR, that would mean I would have to be able to tow around 5000lbs Any suggestions?
