When you install the trailer hitch as I just did, do you cut loose the plastic protector that you remove before installing the hitch and let it hang loose or do you cut it loose from the thin plastic strap that affixes it to the frame. Seems to me if you left it connected it would get destroyed flapping around under the rear end. I am sure one of you has the answer.
