1 - 20 of 266 Posts
West Coast Pit Crew
Here's a chance to be a true Fanatic....:thumbs
Below you'll find a list by state of emergency parts that are available from other Fanatic's to use in an emergency. With everyone doing upgrades I thought it would be cool to offer the OEM parts we are storing in our garage's to other Fanatic's in case of an emergency. Parts are free to use the only thing we ask is when you return home and get your SSR fixed that you ship the parts back at your expense to the person you borrowed them from so they can be offered again to someone in need...:flag
If you find yourself out on vacation or broke down on a road trip these parts are available for use to get you back on the road and home again. We our a close niche family here, if your towed into a dealer and they can't find you a part show them how strong we are as a group. Have the Service Mgr. get on line and show him or her this thread (they will let you) to find your part. Nothing worse than leaving your baby behind at a dealer to wait for a part because you have to get back home from a now spoiled vacation.....:(
Any Fanatic's wishing to list parts post on this thread and make sure you are also listed on the pin map. Also check to see that your avatar shows your city and state
If you have no parts to list tell other Fanatic's about this thread so they will list their parts. If you get one Fanatic to list an emergency part that saves another Fanatic than you have helped in this thread also. :grouphug
I will add parts as each of you post. They will be listed here on post #1 by state and Fanatic handle (easy reference) and also though out this thread....:thumbs
Find your part & Fanatic and then go to this link for contact info: SSR Owners Pinmap V2
FLORIDA
Purple Penelope: Set OEM Tires & Wheels / OEM Rad. Fan
vettegirl: Set OEM Tires & Wheels / OEM Sway Bars / OEM LS2 Intake
Neal2004: 04 OEM Driveshaft / Serp. Belt / Water Pump Belt / Air Dam
hawaiinfun: 2 19" Tires
Beach potato: Covered for breakdowns night or day see post #51
waysouth6speed: OEM 3.73 Gear-6spd / 2 Pumkins- 6spd / OEM Springs / Engine Cover / OEM Air Dam / Extra PCM / Knows great dealership in south Florida / spare ride & extra room if needed -WOW !!!
The Kid: OEM Side View Mirrors
Neal2004: Two OEM front unmounted tires
sharptoys: couple OEM mounted 20" tires
ruby2: two new oem frt. tires / 2004 oem brake discs & pads / oem torque conventer / roof gasket / L & R door handles / oem 04 intake / / oem springs / ignition switch / chrome center caps frt. & rear / oem crossover pipe & heat shields / 2 vol. maint. manual to lend / top assembly training manal
SoonerRed: 1-20" unmounted Firestone / OEM sway bars / 3.73 AT gears / good tech @ dealership / and most important a garge fridge w/ BEER while you wait....:cheers
jxtals: 2 rear Firehawks (unmounted) 3-4k tread left
mike in orlando: Full set of Rims w/mounted Goodyears
CALIFORIA
BlueStreak: OEM Rad. Fan / OEM side view glass mirrors
crazyrtr53: OEM Rad. Fan / Lower Rad. Support / OEM 19" spare wheel with mounted tire / OEM side view glass mirrors / Frt. & Rear springs / OEM air box / extra lug nuts
shiftz33: OEM Rad. Fan / OEM Lower Rad. Support / 19" u/m Tire & 20" u/m tire
lloger: 19" u/m Tire & 20" u/m Tire / OEM Springs / OEM Sway Bars
RickSSR: 1 20" OEM Tire & Wheel
abadssr: Have tools, floor jack, room & place to park for repairs in San Jose / spare tire
StrokerMcGurk: OEM Rad. Fan
frank belk: I work @ a Chevy Dealer in parts / approx 1/2 between La & San Diego on the coast. Would be happy to help any SSR owner anyway I can....
parrotbobssr: Pair OEM rear wheels & tires / one slightly bent frt. wheel (It'll get you home) / OEM springs & sway-bars / 04 door panels w/updated handles
kwhopper89: 2 Frt. & 2 Rear tires mounted and ready to roll
LTs SSR: Two Rear Tires
yellow bear: oem rad. support / 03/04 hood prop rod / oem main cooling fan / 20' spare tire
ssjeff: 19" & 20" OEM Tires
Theturboman: every sensor / every engine seal or gasket / engine parts / Tech 2 diagnostic tool to read codes.
TEXAS
wildcat66: Hood Prop 03/04 / Bumper / Engine Cover / Fuse Box Cover / Tire's & Wheels
Nancy24: Set of OEM Tires
OP: OEM Tires & Wheels 19" & 20" / Driveshaft (Auto) / OEM Sway Bars / OEM Fan
Greg Ducato: Will help with Transmission problems for anyone traveling through Texas
WAYNESWORLD: two 19" spare tires / ignition switch
ssr3: 2 mounted 20" spare tires
gmpartsguy: oem 19" wheel & tire (spare)
ILLINOIS
flynss/r: 17" tire & wheel spare
schweet truck: Set OEM Tires & Wheels
Flying Dog: T/B Spare Tire & Wheel / OEM Air Dam
schweet truck: 2-19 ' & 2-20 " OEM Wheels & Tires mounted
MICHIGAN
Scott 0168: Tire & Wheel Spare
rhobbel: Set OEM Tires & Wheels
HarleyGuy: OEM Fan / OEM Rad Support / Ignition Switch / Thermostat
MISSOURI
silverssr05: Lower Rad. Support / OEM Air Dam / Set OEM Tire's & Wheel's / Set Improved inside Dorr Bezels / Ignition Switch
GEORGIA
Old Chief: Set of used tires / Shop with lift & tools
MASSACHUSETTS
artlemire: Set OEM Tire's & Wheel's
HAWAII / MAUI
MauiMike: 2 19" OEM Tire's / 05-06 Alternator / Ignition Switch / Lower Rad. Support / Tailgate (slight damage) / #1 & #2 Key Fob's / OEM Taillights
TENNESSE
popsssr: OEM Rad. Fan
pikeville904: 1 u/m OEM Tire
Twinkie: OEM Cooling Fan (Phone & Area see post #176)
WISCONSIN:
FUZZY: Set OEM Tire's & Wheel's (see post #57 for service available)
NEW JERSEY
NJ 05SSR: OEM Rad. Fan
CrosscheckFreak: 06 Intake / engine cover / air box rear cover / fuel rails / injectors / throttle body / see post 85 for further help
JIMJOEVAL: OEM Rad Fan / OEM Rad Support / OEM Side View Mirrors / Spare Tire
NEW YORK
SSR6SPD: Too many to list see Post # 24
UTAH
mikepowell: Too many to list see Post #27
NEW HAMPSHIRE
rick15: 6.0 Engine Cover / Face plate for in dash cup holder
VERMONT
Rube: OEM Rad. Fan / 17" Spare Tire
Mason57: Air Dam
CONNECTICUT
john morano: If driving I 95 or Rt 15 in Fairfield County and have a problem give me a call 203-929-5857
quick silver: OEM Rad Fan
NEW MEXICO
saharajohn: Front & Rear u/m Tires and Rooms too.....
DaRetOne: 1-19" & 1-20" mounted OEM tires
IOWA
jdpainter: 4 18" spare's mounted on wheels
ARIZONA
JoshInAZ: 19" Wheel
Doug Allen aka: Parts Doctor: Has anything you would need plus a hauler to pick you up if you don't have towing service. Phoenix & Central Arizona area...:thumbs http://www.ssrfanatic.com/forum/f22/ssr-parts-exchange-38967/
C1Trob: 1 used GY 20" / 2 used GY 19" / oem air intake / 12 oem lugnuts / oem muffler/ oem 4" exhaust tips / oem plastic bedliner
PENNSYLVANIA
bgetz: Spare wheel & tire
RaticalSSR: OEM frt. & rear wheels & tires mounted / OEM cooling fan / OEM sway bars
xoxoxoBruce: Ignition Switches / TLAT Switches / Mikes Main Fan / OEM Wheels w/Tires / OEM Signal Flasher
VIRGINIA
Gary G: used/unmounted two 19" OEM tires & two 20"
BIG JIM: one set of 4 wheels & tires mounted ready to go
SOUTH CAROLINA
leeb: 19" OEM Tires
KENTUCKY
purple flash: 1-19" & 1-20" OEM Tire & Wheel / 1-Ignition Switch
NEVADA
Bert Schneider: OEM Fan / 2 OEM 19" Tires (unmounted)
YellowDZH: Headlights / Fog Lights & Bessels / wiper arms w/blades / air dam / coolant tank / oem rad support / 6 sp shift knob / alternator / 06 engine cover w/ satin insert
oldxr: 19" & 2-20" OEM Tires / 19" & 20" OEM Satin Wheels / Alternator
NORTH CAROLINA
Costal Plains Flash: oem fan / spare tire/ pcm
2fasttoon: oem fan
MnMs Toy: OEM Fan NIB / OEM Rad Support / Ignition Switch
ALABAMA
06 Blue SSR: Set OEM Tires
Colorado
blackbeauty03: oem rad. fan
South Dakota
Buffalo: oem " spare tire
Louisiana
Matman98: 19" Spare Tire
INTERNATIONAL LIST
CANADA
turnheadz: Langley B. C. - Set OEM Tires
United Kingdom
PHASEONE: spare ignition switch
LIST CURRENT TO PAGE 8 POST 239
Tu-Tone club member
Good thread content....
I have tires on rims both 19's and 20's, OEM fan, available for those who may need it coming thru the Panhandle. My info is in the Pinmap.
P/P
Peace:flag
:agree and it should go along w/ the locations of spare tires and wheels that are available across this great nation :flag
Tu-Tone club member
And...it is in that thread. Just trying to include my stuff that's available.
P/P
Peace:flag
West Coast Pit Crew
Parts is Parts...:D
If everyone post's their location in their avatar and also contact info on the pinmap anyone stranded can look up the list for a part they might need. Nothing worse than leaving your baby behind at a dealer to wait for a part because you have to get back home from a now spoiled vacation.....:(
P/P
Peace:flag
I was just agreeing w/ Tony, it's a great idea! You & I posted on the same minute. Ray told me what a great help you were to him when they arrived in FL. :angel
Even here, I've manage to help a few other owners in need. Front tires, alternator thanks to Jeff-SSR6SPD, Ignition switch, exterior and interior parts, rad support.....
Keep up the good work! :flag
West Coast Pit Crew
Discussion Starter #7 (Edited)
This is what I mean.......
I was just agreeing w/ Tony, it's agreat idea! You & I posted on the same minute. Ray told me what a great help you were to him when they arrived in FL. :angel
Talked to a guy in a Vette Club he said he know's of us (Fanatic's) and was very impressed with how close we are and how we are very helpful to each other..:thumbs
Oh! he also said he know's we are a little :crazy too.......:glol :glol :glol
C'mon Fanatic's add your parts to this thread to help a brother or sister in need......:thumbs
I have an '06 OEM fan. Info is on the pin map.
2004 UV
more work for you, but...
Hey :crazy Tony...this is a great idea but how about you edit post #1 with the info folks give, you know, kinda like...
California
BlueStreak - OEM fan
then folks could look up Dwight, see where he lives and give him a call. Otherwise, there is so much chatter on threads like this that some folks, like me, will get frustrated and give up.
I have some stuff too but won't do any good to post until we get the garage cleaned up and we can get to them (Tim says its all my crap :nodno ):glol :glol
Resident Rocket Scientist
Not much for parts at my place but I can always mount up for an SSR rescue run or do some wrenching to get one fixed up and rolling again.
I was driving in Universal city tx today... I saw a red SSR turned around and caught up with him Blue is faster.......anyways met a SSR owner,,get this ,,, he lives about 2 miles from me as the crow flys....nice guy also ..told him about the site... back to the story, he told me he was traveling to Houston from SA..just got in houston city limits and the fan quit ,broke whatever, he stopped at the chevy dealer and they said he needed a new fan,,,well he said they charged him 500.00 for a oem fan and 400.00 to install...I was flabbergassed...he did not have any choise except pay the dealer and get on down the road,,,,,,this dealer in on IH 10 going into Houston,,,,if you Houston folks read this ..please do not use the dealership...I think the name was mac haik chevy ???not sure ...the gentleman did not know about our site here...gave him the info to get here...so next time he would know what to do>>>>>
Bought mine at Mac Haik on I-10 in Houston. Except for a hiccup with the guage changeout - never had too much problem with them. In fact, they were the first to solve the misaligning window problem in '04.
do you think they would take advange of one of our brothers?????
West Coast Pit Crew
Discussion Starter #15
Not a problem
California
Wanted to see the interest in this thread. Seems everyone thinks it's a good idea so I can edit the 1st post like you suggested by state....:thumbs
Oh!! hurry up and get to your crap so we can list it, might get someone home after a break-down....:glol :glol :glol
Spare parts
We definitely have lots of parts.....
can't seem to quit adding or changing! LOL :crazy :crazy
We'll be making a list and sending another post but I know we have the factory radio, hood, wheels, radiator, gears, etc., etc.
Smokey & BlueSSR:black: :blue:
West Coast Pit Crew
Discussion Starter #18 (Edited)
I'll list your parts when you have a full list posted....:thumbs
Also please note all Fanatic's should list their year of their SSR. Different parts for different years...:D
West Coast Pit Crew
Discussion Starter #20
Any one else...............................
Want to list parts to help out a fellow member?????....:thumbs
1 - 20 of 266 Posts
