1 - 1 of 1 Posts
NUTS and BOLTS: For a long lasting and clean appearance of your fasteners, try replacing them with the identical item in STAINLESS STEEL.
Most can be found at your local hardware stores. As an extra bonus the stainless may be polished to a finish that will closely resemble polished chrome. By doing this, it will help eliminate constant cleaning and provide a rust free (Grade 300) or rust resistant (Grade 400) part. This suggestion should only be used for those parts not requiring a high tensile strength. If the high tensile strength is needed the place to address is ARP (Automotive Racing Products) in California. More than likely, they will have the part you will need in a Grade 8 or better in stainless.
1 - 1 of 1 Posts
