1 - 6 of 6 Posts
Ok. I bought a set of side saddle boxes that were 'take-outs' of a new SSR.
I didn't have instuctions for installation, but it is not too complicated.
However, I think it was a take out from an '05 but want to know if anyone has found this issue....
The bottom rail slides in fine and the 3 point attachment is not a problem but the rail on the side of the box that the single small metal piece goes into seems to be bigger (wider) than the slot in the rail.
Anyone else encounter this?
Is the box side rail of an 05 slightly wider than an 04?
Do I just grind down the little piece of metal that the wingnut/bolt goes into so it fits into the rail?
The piece I am trying to slide in is rectangular not square. The narrowest part of this is still wider than the side rail.
Am I making sense?
:flag
Go to the end of the rail by your hinges for the bed cover. pullthe plastic piece out of the end of the rail. then the piece should slide in there at that point. put back the plastic end cap slide it where you need it. On my 03 I could not get it to slide in on the back end by the tailgate.
Good luck.
BobA :thumbs :flag :seeya
· West Coast Pit Crew
D Ring's
Am I making sense?
:flag
Hi Dave
Got mine today and put them in. The metal slide bolt goes narrowest part in and curve of bolt facing inside to bed of truck so it will lock when you tighten up the D ring :thumbs Feed those in the track at the end by tailgate!!
The fix is in.
I had mine in and out once. The problem I had was all the sharp edges and corners on the slide nuts. They grab on the aluminum and prevent them from entering or sliding easily.
So go get a mill smooth file and round all the edges and corners smooth. Or use emory cloth. Or both. :)
Discussion Starter · #5 ·
This was the hot ticket. A little filing and poof she slid right in.... :thumbs
:flag
Discussion Starter · #6 ·
crazyrtr53 said:
Hi Dave
More good advice - thanks Crazy.
1 - 6 of 6 Posts
