I finally got some tunes in this beast.
I took the compressor/tire fill kit and put some self stick velcro (the male side) on one side. Then I put it in the bed on the front wall. That opened the space behind the driver's seat for some upgrading. Now, in addition to a heated seat in the winter, we have a vibrating driver's seat all the time.
The subwoofer is a Kenwood Woox. It's a powered sub with dual voice coils and 100 watts. It fit with only a little bit of Dremel action. It has a wired remote so the output can be adjusted on the fly. The inputs to it came from the wiring for the main door speakers. The rears do not output enough to use. Fiddle with your fader to see what I mean. It's not even worth replacing them.
I added 150Hz bass blockers to the main door speakers. That got rid of the annoying rattle and distortion from them when you tried to get some bass. The sub is set to cover to 160Hz.
I added a pair of Kenwood tweeters. The door mids are exactly behind my long legs so I couldn't hear that output. The tweeters have an inline hi-pass filter.
Here's some pictures.
Diggs
Diggs
