A friend need a set of OEM '04 floormats.
Jack
Jack
Are they different from 03-04 to 05-06? I have 3 sets of mats, used of course but I think they are 05-06 if it makes a difference They can be had very cheapA friend need a set of OEM '04 floormats.
Jack
Yes, that is correct. The 03-04 has a deal pedal area where you can rest your left foot, the mat is not as wide at the top area where the pedals are. The 05-06 was changed to accommodate the 3 pedal arrangement and the dead pedal area is pretty much gone, the mats are wider at the pedal area.Was it when they went to the manual transmissions they changed the floor pan? The engines are the same exterior dimensions and they are in front of the firewall so they should not have needed to change anything for that.
