My SSR started biting the upper seal on the passenger window same as reported below. The dealer didn't believe me when I reported this had happened to others and the solution was to adjust the window tilt.
After replacing the seal, (it runs around three sides of the top panel) the bite was worse. Now, they were willing to adjust the window. They too, ran into the problem where putting the inside trim panel back on caused the window to tilt back outward. To correct this, they had to, crank the tilt adjustment all the way over.
I'm suprised that putting the inner trim panel on could cause the window tilt to change.
Quote from houtex:
I had that problem significantly when I first got the car. Dealer had to open the door panel and realign the window - also found that replacing the pane altered the fix, so they had to allow for that the second time.
Houtex
