dougnc said:The manual says 30 to 36 psi, but someone here once said 30.
Is that the right tire preasue, 30?
comley said:I run 30 psi and have about 15000 miles on tires. Wear looks good and even across the tire. :thumbs
tire heat does not mess with the nitrogen as it does with the air,put 30 # pounds of air in cold tire then go drive it for 1/2 hr. and it'll come up alittle.ampmop said:30 psi is what it says everywhere I read. JimG doesn't run air but instead nitrogen.
Hey JimG, tell everyone here why you run nitrogen in lieu of air...
beer100 said:30 psi is what it says if you look in the door frame.
I run 30psi and I have 25Kmi on my tires. The rears are showing some signs of wear due to overinflation.
wildcat66 said:Gee James are you trying to tell us something???![]()
freezer said:The ride and handling package was developed at 30 psi. You need to use 36 psi when you have a heavy load.
That guy Stacey on Trucks TV also just showed off his recent "Nitrogen" tank for filling tires. Not only does it not expand as much, but it has zero water vapor. That keeps the internal surface of your wheel from corroding, and therefore possibly causing leaks.ampmop said:Hey JimG, tell everyone here why you run nitrogen in lieu of air...
Good Question, anyone know about a place in the Central Texas area, please list.ssr71 said:That guy Stacey on Trucks TV also just showed off his recent "Nitrogen" tank for filling tires. Not only does it not expand as much, but it has zero water vapor. That keeps the internal surface of your wheel from corroding, and therefore possibly causing leaks.
So, since the majority of us can't afford (nor have space) to put such a setup, where can we get our tires evacuated and refilled with nitrogen?
I KNEW you would come through with some good information. Thanks.JimGnitecki said:My experience with nitrogen has been impresive so far.
Yes, it is true that nitrogen expands a little less with heat than a normal mix of air does, it does not corrode alloy wheels from the inside like normal air mix does, and it is very pure compared to normal compressor air.
But what really got me was the other benefit: much slower diffusion through the tire and wheel (i.e. very slow "leakage" even when there is no puncture in the tire).
How slow? Well, I got my tires filled with nitrogen at Butler Tire in Atlanta on 4-27-05, with 7500 miles on the odometer.
It's now 8-09-05, 104 days and 6000 miles later, and guess what: Until just a few days ago, there was ZERO loss of pressure from ALL four tires.
Then, just a few days ago, 3 tires came up ientical to before, but 1 came in 2 psi lower. Since they had all been identical just 4 weeks ago, I assumed that sometimes in the last 4 weeks I had acquired a slow leak via a semi-sealed puncture.
I took it to a Goodyear tire dealer to FIND the cause of the pressure drop. After 30 minutes, the technician gave up. He literlaly could not detect a leak, and opined that if there was indeed a leak, it was either SO slow that normal testing could not find it, or the valve stem might have at one point leaked a bit but then resealed itself. He did not dismount the tire because that Goodyear dealer does NOT offer nitrogen fills, and he did not want to have me end up with 3 nitrogen filled tires and 1 air filled tire.
So, I am impressed.
It is ok to mix air into the nitrogen. Just realzie that you are affecting the properties a bit, and might not want to go roadracinguntil you get all 4 tire in nitrogen again. NO harm is done, other thanyou will now need a complete purge of that tire when you do find nitrogen.
I am told that there are some surprising sources for nitrogen. One is apaprently Walmart, at least at some of their auto repair locations.
The big attraciton for the retailers is lower liability. Since nitrogen leaks slower, and expands less, than a normal air mix, neglected tires will go longer before they cause a catastrophic crash which the stupid owner and his lawyer then try to pin on the last tire dealer who worked on the tires.
Check the yellow pages in your area, and start with Walmart.
You are right, Machel. I got mine filled at Costco. They didn't actually evacuate all the air from the tires. They removed the valve core and let the air out, and then filled with Nitrogen. About a month later I picked up a nail and had to have the tire fixed, so I went back to Costco and they didn't want to refill the tire. The person I spoke to said they were not supposed to work on tires that weren't bought at Costco. He finally agreed to do it, but said that was the last time.wildcat66 said:I think Lloyd said he got his filled at Costco! Aircraft Maintence Shop fill aircraft tires with this so maybe you could get it filled there. If you know someone at an airport.
