Ok, here's my story. I had an issue with the top binding on the SSR and Mike in AZ helped me work around that problem by replacing the hinges since I had the early versions. The top now does go up and down beautifully, except for one thing.
The panel that has the latch hooks on it for that final stage doesn't go down all the way. It's not a lot, but you can see it's just not seating down on the weather striping. Before the hinges were replaced when I took the truck over to Mike, he explained that upon initial action of raising the top you hear the two clicks from the latches releasing. It has never made that noise since the latches were installed (by me). I have tried adjusting over and over hook parts attached to the panel that the latch slides in to to secure it but it still wont seat down all the way and no clicking at all is heard.
Any suggestions on what I might look for or if any of you are familiar with this type of situation and can send me down the proper road
Thank you all in advance for your responses!
S2NAZ :ssr
S2NAZ :ssr
