1 - 15 of 15 Posts
I'm guessing theres a drivers door data tag sticker that has the paint code? Trying to determine if the SSR i'm interested in has been repainted, thanks
Glove box. What general color does it appear to be? Only a limited color production by year.
Paint Codes
Aqua Blur......................26U...........................WA‐214M
Smokin Asphalt..............41U...........................WA‐8555
Ricochet Silver...............67U............................WA‐994L
Redline Red....................70U............................WA‐9075
Slingshot Yellow.............79U............................WA‐423G
Pacific Blue....................90U...........................WA‐885K
Ultra Violet....................21U...........................WA‐245E
Reactions: richsadams
If you had a picture we could probably tell you what color it is. Did you look in the glove box? The code is in there right on the door. If you had the VIN and contacted "CASH" on this site he may be able to tell you what color was on it when manufactured but if they repainted it then it could be any color and only the painter would know what he painted it.
:p
Auggie, it seems this ride just might not have a (glove box door). Who knew.:p
I suspect the vehicle is locked and he can't see in the glove box and is trying to find out a different way so he knows the color before he would buy it or make an offer. But that is a needle in the hay stack type thing.
Discussion Starter #7
Trying to determine if its a true two tone SSR or has been painted to resemble one. Auggie any chance you could text me? 2182424540
I don't text. There is three ways to tell on a two tone.
1. There is a two tone list and it should be on there if it was original.
2. Get a hold of CASH like I said he has almost all the VINS and colors.
3. Depending what color it is they only made about 4 two tone color combinations.
1-605-787-9136
Simple solution for your request . . . the Build Sheet which can be retrieved with the VIN.
Very possibly there is a Build Sheet already posted under "Build Sheet Requests" but if not, post your VIN and be patient.
Good Luck and WELCOME.
Super Moderator
I was about to phone you but glad you figured it out
From Auggies post
Paint Codes
The second column is the GM paint code
The third column is for ordering paint from a paint shop so they know the mixture
Can you give me a call Cash...it would be nice to confirm what i think im seeing
You might have to send him your number via Conversation since we have no access to that personal information.
Missed that one. Oops!
1 - 15 of 15 Posts
