I have a problem with my drivers side window track. In the winter when the window freezes to the rubber and you open the door the track still moves the ½” while the window remains stuck in the up position (no movement). This makes the window fall off the track.
I have taken the door panel off and tightened / adjusted the window a couple times so I have that down. There is an epoxy or hot melt adhesive in the center of the window track that is not holding and I assume it is there to prevent this problem. What is the epoxy or adhesive to use?
Thanks in advance…
Thanks in advance…
