Window Roll
IF THE WINDOWS DON'T ROLL DOWN THE 1/4 ", IT WILL NOT CLOSE PROPERLY INTO THE RUBBER WHEN YOU GO TO CLOSE THE DOOR. THEY WILL BE ON THE OUTSIDE OF THE WEATHERSTRIP, AND LOW AND BEHOLD, YOU HAVE A MAJOR WIND NOISE.
IF YOU ARE GOING TO HAVE YOURS TINTED, AS I PLAN TO DO IN THE SPRING, A REPUTABLE WINDOW TINTING DEALER WILL ALLOW FOR THE 1/4" OF THE WINDOW THAT RUBS ON THE WEATHERSTRIP. (AREA THAT WILL NOT BE TINTED TO KEEP IT FROM PEELING. ANOTHER OPTION IS TO CHECK IF ANYONE IN YOUR AREA DOES THE SPRAY ON TINTING. nOT SURE HOW THIS LOOKS OR HOLDS UP, BUT IT IS AN OPTION.
