1 - 19 of 19 Posts
Looking for a wiper motor for an 03. Must be in good shape to install in a customer's vehicle.
Wayne
Thanks, Mike. The wiper motor cover kit fixed the problem. You are the best.
Good to hear.
I'm sure that once I open my mouth and say this, someone will send me one...... but I have not seen the wiper motor, itself, fail yet......
All my best,
Mike....what is the problem with the wiper motor? What is the fix you offer? Just curious for my reference. Thank you.
Dane
Dane
Hi Dane,
To my knowledge, there are no problems with the wiper motor. I have never seen a failed SSR wiper motor.
All of the wiper and washer signals go through the electronics module that is attached to the bottom of the wiper motor. GM does not recognize it as a separate part for the SSR and therefore calls for replacing the entire assembly (motor and electronics module) in case of an issue. Please note that this part (SSR wiper motor assembly) is no longer available.......
What they (GM documentation) don't realize is that the motor and module are identical to the ones in the Trailblazer/Envoy. After running this down about 18 months ago, I began to carry (on my web site) the electronics module for the bottom of the wiper motor. To date, this module has fixed all of the wiper and washer issues that I have come across.
Regards,
Mike....thank you for that info, as usual you've come through for the benefit of the Fanatics and I really appreciate your involvement.
Dane
Hi Dane,
Regards,
Hi Mike,
I just experienced an issue with my windshield wipers not turning off on my 05 SSR. Looked at the related fuse behind passenger seat and it is good. If I remove it, of course the wipers do not work at all. When in place, I can;t shut the wipers off and they remain on until I turn my SSR off. I too thought the problem was related the wiper motor. So, my question is where would I purchase a wiper module to have the dealer replace rather than the motor? Thanks! [email protected]
@dodger just a heads up Mike is off line for a couple days taking some vacation time with no internet or phone service, so be patient and you will hear from him in a couple of days.
Gentleman, thank you for Mike's status as well, thank you Dicktator for the advice on the multi-function switch. My SSR is in Germany at the moment and being transported back to Iowa next week. Once it arrives, I want to have this issue taken care of and don't want to have this elongated conversation with the Chevy dealer about ordering the motor, wiper module, and multi-function switch in order to solve the issue. I may be wrong, but my plan is to gain all of your expertise and hopefully be able to purchase the parts on-line somewhere and then take to the dealer to replace. Again, appreciate your support!
I have found that my dealer is thrilled to have a printout of Dictators Power point if I provide the parts and then the labor is less as well because they save time*.
*All dealers may not follow this example.
Do you have to have thoes numbers for the wiper motors and module that are identical to the ones in the Trailblazer/Envoy. My wiper is not working and Ive been told by my Chevy dealer mechanic in Boone NC that they cant find one. My SSR is a 2004. Any help would be appreciated.
#SSRBNC - Michele
Trygodfirst
2006 FPR SSR PAC BLUE AUTOMATIC
Hi Dane,
Regards,
You are the man Mike
1 - 19 of 19 Posts
