  •  2022 Ride of the Year
1 - 20 of 20 Posts
· Senior Privileged Member
Just in case anyone is wondering if you can add the wood strips to a base (not optional deluxe) cargo area, the answer appears to be "yes".
The 04 SSR I bought happened not to have the deluxe cargo area option, and I was glad, because I did not want fixed in place carpeting for 2 reasons (1) weight, and (2) susceptibility to moisture problems. But, I really like the look of the wood strips.
Teri on this forum ran an ad recently in whic she offered to sell her set of wood strips, and I bought them.
The 2 outer strips install easilyin any SSR that does not have side saddlebags, by simple insertion into the left and right guide strips on the floor. They remove simply by deflecting a spring holder, and sliding them out.
The 7 inner strips each come with 7 velcro 1" x 1" patches with velcro "hooks" on their backsides, which evidently hook onto mating Velcro "loop" patches sowed onto the factory carpeting.
Since my SSR does not have that factory carpeting, I had to provide those "missing" velcro loop patches, and have them correctly positioned. here is how I did that:
- I bought a 2" x 49" strip of Velcro hook and matching loop "self-adhesive tape" material at my local OfficeMax. Note that I specifically went looking for the "Industrial Strength" part number of velcro, not the "ordinary" grade. The difference is not in the velcro loops, but rather in the adhesive. The "INdustrial strength" part number uses a MUCH stronger adhesive designed for heavy duty use. I figured I need that to be able to bond reliably, under loads, to the slick plastic bedliner material.
Note that the industrial strength type velcro only comes in 2" wide strips versus the 1" I needed, so I simply cut the strip lengthwise to get a strip 1" wide. Then, I cut the resulting strips into 1" x 1" patches.
Note also that this velcro hook material comes with a plastic backing material that keeps the adhesive protected from air until you actually peel the backing material off and apply the velcro strip to a surface. Tenm the adhesive glues the velcro strip to the surface, and cures to maximum (industrial!) strength in 24 hours.
- I cleaned the bedliner surface using isopropyl alcohol that I bought at the grocery store. This was intended to ensure that all dirt, grease, and remaining mold release was removed prior to attempting gluing the patches into place.
- Then, I pushed a 1" x 1" loop patch onto each of the 7 hook patches on the back of one of the wood strips, still leaving the removable backing material in place on the loop patches. This meant that I now had a male hook and female loop in absolutely correct alignment on the back of the wood strip, but with the backing material sitll in place
- Then, I took several minutes to carefully fold back one corner of the backing material square on each of the 7 loop patches. I did this because it is HARD to peel the backing material off of each 1" x 1" patch, and I didn't want the adhesive curing before I had actually APPLIED the patches to the bedliner!
- When all 7 patches had a corner of the backing material folded back, I quickly whipped all 7 backing mayerial pieces off, and carefully laid the wood strip into proper position in the bed. I then put hand pressure on the wood strip to ensure that each of the 7 velcro loop pataches had "good contact" with the bedliner. Then, I let go (the adhesive used is VERY elastic, so once contact is made, no enduring pressure is needed).
- I repeated for each of the other 6 wood strips, being careful to keep the ends of the wood strips aligned with each other (If I did it again, I would have thought of using a strip of masking tape as a highly visible, reliable, and easily removable guideline)
Today, aftere 24 hours, I checked the results. The bond appears strong. I was able to remove one of the wood strips by pulling straight up to release the velcro, without hurting the apparent bond of the loop patches with the bedliner!
The resulting look is VERY nice. You have the lightweight plastic, non-moisture sensitive bedliner being accented by the beautifully finished wood strips. Looks fabulous.
If you need to remove the strips temporarily for any reason, you can simply tear off each strip vertically thus releasing the velcro. When you want to reinstall, just place into position and press down to engage the velcro.
I THINK this setup will not result in the wood strips being deflected off their velcro mount points UNLESS you place an object with protrusions in its bottom surface onto the wood strips (like say a heavy toolbox with protruding "feet"). I suspect that under dynamic driving conditions, an object with protrusions WILL likely successfully deflect a wood strip off its velcro mounts if it is heavy enough. But, suitcases, boxes, and bags without small sharp protrusions should be just fine.
I also have a custom-made serged carpet peice that just covers the bed of my SSR, and that can still be placed over the wood strips whenever I want a carpeted floor for appearance, to protect luggage, or to protect the wood strips.
In addition, the back of the carpeting can be also be rolled "under" instead of fully extended, so that objects placed at the back of the bed, where they can conveniently be reached from the back of the tailgate, can be kept from slidng forward by the obstructive action of the underturned carpet!
When I need FULL control of MANY items, some of them heavy, I can still place my collection of pre-fitted "Container Store" clear lidded containers on TOP of the carpeting (carpeting protects the wood strips against the containers moving around a bit). Since the plastic containers are only about 6 inches high, ad have lids, I can lay large objects on top of them.
I figure I have close to the ideally flexible cargo area now. I may still buy a cargo net or set of side saddlebags to give me the ultimate in flexibility "for any reasonably foreseeable cargo carrying needs".
When I want just plain beauty, I'll take out everyhting but the wood strips!
Thanks, Teri. The wood strips worked out well!
Discussion Starter · #3 ·
I'll try to get photos of the installed wood strips in the next day or 2.
Photos of any of the rest of the package would really be a logisitcs nightmare as I am living in a hotel, on the 2nd floor, while on this contract assignment in Atlanta, and the custom carpet and containers are in my room! I need a hotel luggage trolley to bring them down, and have to haul the trolley right through the lobby of a fairly nice hotel, so photos of them will have to wait until I am in my home again!
Discussion Starter · #5 ·
Devastator: I don't want to push things: the hotel management already lets me park right in front, JUST OUTSIDE the lobby, right outside a window from their office, so they can keep an eye on it for me. I have been doing that for 9 weeks now, and might be here anywhere up to 10 months more.
Abusing the hospitality might be a mistake! :)
Discussion Starter · #7 ·
I am a computer systems consultant. I was retained by SunTrust Bank to help them develop a plan, a delivery model, and then actual implementation of an enterprise-wide FileNET (document technologies) infrastructure.
We did a good job on the plan and delivery model over the past 2+ months, but now despite senior IT management's apparent enthusiasm for the implementation (it was they who asked for the plan, delivery model, and implementation!), they sem to have a problem coming up with the actual dollars and people to invest in the implementation!
If they perform to match their intent and words, I'll be here another 10 months or so. If they don't, I'll have to find another assignment!
Bed Strips
Since the dealership has STILL not gotten us our carpet (it's on one heck of a backorder, I guess), I decided to do something similar to what Jim did.
We have the silver strips instead of wood.
Picture? Here ya' go.
Diggs
Discussion Starter · #10 ·
houtex: GREAT idea.
The outer strips are going to require some routing, in orer to fit into the channels in the bed. But the central strips can be pretty straightforward.
I used to be a bigtime woodworker, so here are some ideas for you:
- The strips could be offered in mahogony or oak, as well as in exotic woods like Padouk, Zebrawood, Purpleheart
- They need not be the same dimesnions or profile as the GM ones
Dimensions...
houtex said:
Hey, guys - my hobby is woodworking - what's the dimensions on those strips??
The strips are 33 7/8" x 1 1/16" x 1/8". There are the two outer ones that slip in the tracks and 7 inner ones that go on top of each raised spot on the plastic bed liner.
If you don't want to router an I shape for the 2 outer strips, I think you could get away with velcroing them straight on top of the tracks. In that case, you will probably want to take some measurements of the tracks and make your strips longer than the GM ones.
Good luck and I can't wait to see some pictures. I can smell the sawdust already.
Diggs
Discussion Starter · #13 ·
Here are some photos of my installation.
1st photo shows the wood strips in place
2nd photo shows the removable serged carpet in place over the strips
3rd photo shows the carpet rolled back a bit to make a barier to prevent small items from sliding forward.
· Premium Member
houtex: GREAT idea.
Are these strips available in mahogony or oak?
1 - 20 of 20 Posts
