I'm currently in the mid 40.0K miles range and I'm sure by the time I return from the Rocky Mountain Run in Sept, I should have a little over 50.0K miles.
87,654! Would have been more, but in the shop waiting for the new fuse block for 2 weeks (+/-). Took me a few days to convince them the info from the forum was accurate - and to get them to let me order the block. Just got it back last night. Thanks for the rapid delivery, Marc!
Start out with 3 cooling fans while still in warranty.
a/c control
brake module
water pump
upper control arms
thermostat
5 sets of tires
radiator hoses
inlet heater hose
brake pads at 168000 miles
throttle body @ 196000 miles
rear main seal
shift cable
battery after 5 1/2 years
door check link for left door
Still has original ign. switch and inside door handles.:ssr:ssr
Well after only putting on 50kms/31 miles on total so far this year, I figure after the Rocky Mountian Tour .... Should be around 20,000 kms/ 12427 Miles .... Give or take a couple.
The R only has 15300 kms/ 9506miles on it now.
Well, since I just was able to join the team of proud SSR owners, today about 200 miles. I just purchased a 2004 SSR with 38,351 miles in Ultra-Violet. This one came thru Morrison's Motor Cars in Concord, NC. It has the chrome wheel upgrade, running boards, cargo bed upgrade, cargo net and cross bar, etc. Already turned some heads driving and the 1st question from my 11 1/2 year old daughter in the passenger seat when we picked her up from camp- "Can I drive it when I'm 16?" She was absolutely amazed when I put the top up.
On a seperate note, how would I determine what # truck this is from the 2004 series, ex: # 336 of 10,676. I can also see between the color and the chrome wheel option that this one with a sort of rare combination (color 1 of 1273 and wheels 1 of 1657).
My 2004 SSR Turned 100,000 miles on My Birthday June 7. The day I had usspeedometer rebuild stepper motors. Kelly had 77,000 miles when I bought her Feb.2009. I would have driven her much more but I am on a Fixed income & the Gas prices have kept me Home.
You are perfectly correct with your thoughts ... however IMHO I truly don't believe that there are very many SSRs who will have exactly the same numerical break off points and if so then they should probably choose the next higher numeric category. But if it will make some happier I will be glad to go in and edit the poll to reflect one more mile in each category.
