A new law went into effect on 01-Jan-2019 in California that has a large number of vehicle owners upset. California Assembly Bill (AB) 1824 (Section 4) modified vehicle code (VC) section 40610 so that citations issued for VC 27150(a) / VC 27151(a) are no longer simple "fix-it" tickets. Those citations now carry a fine/penalty that you can either pay or you can attempt to fight the citation by having your vehicle inspected by the state referee (if your vehicle's GVWR is under 6000 lbs).
The reason I'm posting this on the SSR site is because the SSR's GVWR (gross vehicle weight rating) is 6050 lbs (not the curb weight which is in the 4800 lb range). VC sections 27150/27151 have statements of what the maximum decibel rating is for most vehicles which is 95 dbA, but that's only for vehicles with a GVWR under 6000 lbs. If you dig deeper into the VC, you'll find that section 27200/27204 specify the maximum dbA rating for vehicles with a GVWR rating between 6000 and under 8500 manufactured after 1977 have a maximum rating of only 80 dbA, not the 95 dbA rating that most news reports / videos are talking about.
The noise level limits were not changed by CA AB 1824, only the manner in which the citation is handled (fix-it => fees / court).
I've been doing a lot of research over the past few weeks and I've created some videos on my YouTube channel after speaking with the Society of Automotive Engineers (SAE) and the California Bureau of Automotive Repair (BAR).
SAE created the exhaust system noise level testing standards referenced by the CA vehicle code (SAE J1169 - but this was canceled in 2007) and the state referee that performs the noise level test uses SAE document J1492. Those are copyrighted documents that I've purchased copies of for my own private use. I cannot state what is in those documents - (you can purchase the rights to use those documents in certain situations - One year posting on the internet was $1503).
The fact that the SSR GVWR is in excess of 6000 lbs (6050 lbs - check it on your door label on the driver's door) means a lot of the hype related to this issue doesn't directly apply to the SSR.
Vehicles with a GVWR of 6000 lbs and higher (like the SSR), must contact the issuing agency and/or the court to see what the proper solution to the citation is since the VC sections, SAE testing standards and state referee test are all geared to vehicles with a GVWR rating of less than 6000 lbs.
In the description section of the video, there are a large number of links to the various data sources uses to create the video. I have a couple other videos I created on this topic as well (one showing an example noise level test on my Chevy SS sedan).
I hope this video helps explain the situation for us vehicle owners in the state of California.
Links to AB 1824 related articles / websites:
CA Vehicle Code 40610
CA Vehicle Code 27150
CA Vehicle Code 27151
CA Vehicle Code Article 2.5 Noise Limits 27200 - 27207
SAE J1492 Oct 2008
SAE J1169 May 1998
California Bureau of Automotive Repair (BAR) - Vehicle Exhaust Noise Level Certification
AsktheRef.org - Citations and Violations
California Code of Regulations 1036 - Passenger Cars and Light Trucks and Buses
CA Uniform Bail and Penalty Schedules - 2019 Edition
SEMA Org - Fact vs. Fiction: Explaining California’s New Exhaust Noise Law
Jalopnik - Why People Are Suddenly Freaking Out Over California's Exhaust Laws: Explained
SAE J1492 Oct 2008
SAE J1169 May 1998
