2004 SSR Right Side Window Regulator
2 reading
2.3K views 5 replies 4 participants last post by  Dicktator
#1 ·
Help, I am looking for a Window Regulator, does anyone have any suggestions? Thanks
#2 ·
#3 ·
There is window removal in Dicktators Library. One thing that I learned was that you can get to the nuts with the window in the up position and you don't have to remove the speaker to get to the nuts.
As for shipping check with your post office and see if they have the priority box for shipping board games. They fit in them perfectly then will ship at a flat rate. If not lay the regulator on a table then twist them so both tracks are on the same side and it will fit into a smaller box that way.
The people Mike mentioned do a great job they repaired one for me. I called and spoke with them, shipped it the next day. They got it in and repaired in the same day. Shipped back out the next day. For some reason it is usually the passengers side that breaks. Finding a used one from a salvage yard is normally high compared to getting your original repaired and once repaired it is done. Getting a used one it is on borrowed time
If you search on line someone said you can use one from a Silverado and can modify it to work. I tried that and it was a waste of time.
#4 ·
Thanks
