Greetings all,
I just started my SSR in the garage and backed it out a few feet to clear the doors. The DIC read, "Low Oil Pressure, Stop Engine".
History:
I had trouble with the oil sending unit being pinned at 80psi. Through diagnostics it was determined the sending unit itself was bad.
Turning the key to run would always make the gauges sweep and return, in this case 80psi.
Now the oil gauge no longer sweeps, erratic, when it does it will sweep to 80psi then drop to "0".
The SSr runs and sounds fine. The oil level is full and clean. There are no leaks under the carriage either.
Is this a symptom of the same bad gauge in reverse?, or do you think its an accurate indication of a oil pump issue.
I'm afraid to move it.
Thanks in advance
History:
Thanks in advance
